Version of RobotStudio that support Force control
I am currrently using RobotStudio 5.10.
However, it seems that Force Control functionality is not available in the version that I am currently using (or may be I do not know where to activate it).
May I know how can I activate it or which version of RobotStudio should I install in order to have the force control functionality for machining?
Thanks.
  • It should be available through the virtual key, you also may wish to install the ForceControl Machining Additional Option on your PC from the RobotWare CD. Unfortunately, though, I am unaware of any mechanism to simulate the force sensor that is required to use force control, so you may a difficult time doing any meaningful simulation.
    Russell Drown
  • With RobotStudio 5.11 you may install Add-Ins Machining PowerPacs. it's designed for ForceControl simulation.
    with virtural key you can choose RW options 877-1 Machining FC, 661-2 Assembly FC. The limitation is without Additional option key FC GUI & Flexpendant Interface, you can't use the ForceControl GUI (Graphic User Interface)
    Peter
    Hi all,
    I have a problem that the force control is not activated in my robotstudio as shown in the attched photo. Currently I using a trial version. Is it because this is a trial version or some other resones. I have activiated the 877-1 Machining FC GUI and  661-2 Force control base.
    Thanks so much
    RS.png 449.1K
