How to get back write access to VFP?
Sometimes write access for VFP seems taken away to RAPID editor. How can we get it back to VFP without warmstart? Also when is it taken away?
BR
Yu
  • Hi,
    RobotStudio is designed to take the write access for a VC automatically, but only when it needs to. Directly after the operation that required write access, RobotStudio hands it back. If, for some reason, RobotStudio still has write access and you want to do some operation on the Virtual FlexPendant, then you can switch to Manual mode on the Virtual FlexPendant to force it to get write access.
    ABB
