External ax MU10
Rookie
I'm trying to add a MU10 in robotstudio, but it shuts down with an error after restarting. I do have a *.moc file, which causes this problem. Does anybody has a correct moc file and a brief description how to do this correct?
Thanks.
Hello,For simulation in RS you can use the moc files that comes with RobotWare. For a rotational axis you can use this: C:Program FilesABB Industrial ITRobotics ITMediaPoolRobotWare_5.11.xxxxxutilityAdditionalAxisDM1GeneralM7L1B1_DM1.cfgTo run it in RS, import a robot and a mechanism for the MU10, then use "Create System From Layout" to setup the system. When you are asked to point out a cfg-file, point out the one above.Anders S2008-12-15 13:13:39Best regards,
thanks, it worked out for me!0
