Convert station from RS5.10 to RS4
zombee
I d like to ask, if it is possible to convert station from RS5.10 To RS4?
Best Regards for anybody who can answer to me
Thank You
ZombEe
No it is not.And why do you wan't to do that. RS 5.11 is big time better and works allmost prefect.BR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
If I am right programs from RS5.11 will not fit to S4Csystems. True?And that is my problem.ZombEe0
Hi,Programs from an IRC5 controller will run in an S4 contoller providing you do not use any commands that have been added to RAPID since the S4 release.Also you will need to have the same (or equivelent) RobotWare options in the S4 controller.If you look at the other way round it is probaly clearer, a S4 program will run in an IRC5 (providing the same Robotware options have been taken), because commands have been added to the later releases so there is no danger of using an unsupported command.RegardsGraeme0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
