demo palletizer querries
reflex
webwiz/2762/palletizing.zip
Please see uploaded video that is demo palletizer video from robot studio 5.11.
I wanted to make such video in robot studio.But How to make following efffects in robot studio ?
1 sack is automatically generated on first conveyor after few seconds .
2 sack is picked by gripper and is moving along gripper and is placed on pallet.
3 Pallet is seen moving on second conveyor.
reflex
HiYou need to make use of VSTA(write your own code, VB or C#) and the event table to be able to do a simulations like that.Per Svensson
Consat Engineering0 -
hi, reflex
ehm.. yesterday i also make some simulation about palletizer. I'm not using VSTA, but instead using event manager. MAybe the simulation is not smooth as using VSTA, but it will be a alternative way to do a simulation. (actually, i don't know how to use VSTA, so i use event manager,
Good luck
BR,
indah carmila0 -
Hi.1. Sack is made by vsta code tricked by event manager fro a DO.Here is the code for making a box
Public Sub Macro_Create_Box()
Dim Station1 As Station = Project.ActiveProject
Dim box_origin As Matrix4 = New Matrix4(Vector3.XVector, 0.0)
Here is the size of the box
Dim box_size As Vector3 = New Vector3(0.2, 0.2, 0.2)
Dim Part1 As New Part
Dim Body1 As Body = Body.CreateSolidBox(box_origin, box_size)
Station1.GraphicComponents.Add(Part1)
Part1.Name = "Box_1"
Here is the place of the box.Part1.Transform.X = 1.5Part1.Transform.Z = 0.78
Part1.Bodies.Add(Body1)
If Station1 Is Nothing Then
Exit Sub
End If
Logger.AddMessage(New LogMessage("Macro_Create_Box is done."))
End Sub
2. Atchad the sack with event that atchad the neast object to your tool. trickt by a DO,
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
3. You make a mecanicel device to transpot your pallet.
Have Fun
BR. Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
