Extended Compliance Tool
Hi all RAB Programmers
Here comes a Windows Application for running the Compliance Tool so that you don't have to bring up a command prompt.
This product is not offically supported but issues/improvments can be posted here and if I have the time I will try to solve/implement them.
You net to have .NET Framework installed to be able to run the app but I guess if you are developing RAB applications you allready have that.
Per Svensson
Company Specialist
ABB Automation Technology Products
Company Specialist
Hi Per
I have tried your tool, it works fine
but I had some initial problems with the path to CSC.exe
See Ya Later0
