Move frame?
OlofS
Hi!
I wonder how I can move the frame (the coordinate system's origin) relative to an object, because right now the frame is very far from the object and it makes repositioning very hard.
Thanks in advance for answers!
You can use WorkobjectIn Wobj, you have two frameuframe => definition of the table (position and orientation)oframe => definition of the part on the tablesee help for more information (wobjdata)Give me more information if don't answer properly0 -
Problem solved, thanks!
- 367 IRC5
- 858 RAPID Programming
