Lin & RobotStudio 5.07
I am new to RAB forum.
I have RS5.07 version and I downloaded RAB 5.11 version.
Can I develop RAB for my RS 5.07 version?
If not, should I upgrade to RW 5.09 or 5.10 and develop RAB for that.
Please guide me. Thank you in advance.
Lingaa
  • Hi Lin,
    is RS = RobotStudio????
    There has been a lot of changes since 5.07 to 5.11. As an example, 5.11 includes a new set of controls. I will use at least Rw 5.10 and RAB for a good start.
    BR/Carlos
    Carlos Martinez
    ABB
  • If I have RS 5.07 then can i upgrade only the RW.
    Means I have RW 5.07 with RS 5.07 and only install RW 5.09.
    can i do installation only 5.09 to RS 5.07?
    Lingaa
  • [QUOTE=Lin]I am new to RAB forum.
    [/QUOTE]
    [QUOTE=Lin]If I have RS 5.07 then can i upgrade only the RW.
    [/QUOTE]
    Dear Lin,
    Please note that the only way to still have an external version of RobotStudio 5.07 is to have installed the cracked version. Dead Something which is a punishable offence. I would sincerely recommend that you uninstall it, since so far the cracked versions that we have tracked down all install trojans. Ouch
    To answer your question, no you can not install a later version of RobotWare on top of your RobotStudio version to make it compatible with Robot Application Builder.
    Best regards
    John Wiberg
    If you don't know what a trojan is please read this:
    http://www.microsoft.com/technet/security/alerts/info/virusrat.mspx
  • thank you Mr.John.
    I uninstall Robot studio 5.07 and using 5.10 now.
    Thank you very much.
    Lingaa
