Multimove - two robots carrying one object
bombq
hello,
I'm about to prepare station demonstrating carying of one object by two robots,
I wonder how to configure my MM system to do such thing, 2 robots are situated
oposite and another case is when robots are situated in a row (one next to another).
Please help me,
Please help me,
bombq
Cracov University of Technology
hello,
thanks for presentations, now I will try to use and test my MM system in RS.
bombq
Cracov University of Technology0 -
hello, it's me again.
I'mm still trying to configure my station.
I've made a path of 4 identical (the same coordinates) points for tool robot, and a path of different points for workpierce robot, I want tool robot to stay ine one point in workobject moved by workpiece robot. I don't know what is wrong...
I can not obtain effect that one robot is following the other. Here's my station,
if somebody could help me... , please any suggestion will be very helpful.
webwiz/2382/mm3.rar
Regards,
Mat
bombq
Hi,To be able to help you, you need to upload a full Pack & Go file of your station including the system.Best regards,
bombq
Hi,The problem was that the base frame for the tool robot not was correct. In System Configuration, you can use "Use Current Station Values" to define the base frame.
ABB Robotics0
- 365 IRC5
- 38 AppStudio
