Connecting to IRC5 OPC EA Server
tomb
For a scada project i need to get error&event messages of robot to a scada software. I am planning to use Irc5 opc server to get connect to robot and this opc server has an EA server to get error messages. I am using Movicon(also Phoneix Contact) Scada to get error message from ABB IRC5 OPC Ea server.
My problem is i can't see or handle error&event(comes from ABB OPC EA server) messages at scada side like we handle datas that coming from ABB IRC5 OPC DA server and i can't keep a lof file of robot elogs that comes to scada. I can only monitor it.
So i need your help to learn how to use this ABB IRC5 OPC EA server more efectively and record all elogs to a scada based DB.
Thanks in advance.
HnmN
The IRC5 OPC A&E server is a one-way message broadcaster, there is no way for you to interact with it or acknowledge messages. If you need to interact with the robot, you need to do it via your cell controll (PLC or PC) through I/O or by the robot's programming interface (see Robot Application Builder). If you simply want to log robot A&E messages, you need to use a different commercial OPC A&E client that offers this capability or create your own.Russell Drown0
Thank u for your answer.Actually i only want to see and record logs to a db in scada side that is all. So can u advise me an opc server that is more talented than Abbs?HnmN0
Again, the OPC server is not the problem. It is an OPC Foundation-Compliant Alarm and Event Server.
You need to purchase or create an OPC A & E client application that implements the functionality that you need, i.e. logging messages to a database. That is not the job of an OPC server, it is a function that an OPC Client must perform.Russell Drown0 -
I am not an expert on creating opc client aplications so the best solution for me seems to be finding a good OPC A&E client software. Thanks for ur help.HnmN0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
