Move along path
I am a very new user to robot studio. I am using 5.11 and I have been trying to teach targets, and create simple paths for the robot to move (for instance, moving to each corner of a pallet). I have been trying to get the robot to move using the "Move Along Path" command, and it seems to run through the program, but the robot never graphically moves, and I get an error "Program pointer Lost".
Then I tried to use 'Auto Configuration', but I get an error between my second point and my third point called "AutoConfiguration: Target failed: Target_30". This seems like a very simple move, why would I have an error?
Try to use another configuration for the first target in the path.Best regards,
ABB Robotics0
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
