Conveyor Tracking
When I'm looking in the Conveyor setup Form,  it is missing the Mechanical unit  CNV1  and the workobject (see pic2.jpg)
I suspect that some  configuration in the virtual controller is worng.
Could  some one provide me the .cfg files to set up the VC  for the conveyor tracking?
(The example with the paint robot is working correctly)
BR
Oscar
BR
Oscar Ferrrato
  • Hi Oscar,
    In general the only configuration you need is to check the Conveyor Tracking Option in the SystemBuilder.
    PickMaster is not supported.
    Before you add the system, make sure you have a conveyor mechanism library on your file system. You will be prompted for it.
    Then you have to create a workobject and set the property MovedBy="CNV1" and,  UfProg==false.
    Now the wobj should appear in the Conveyor Setup Dialog.
    Best Regards
    Niklas Skoglund
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • Thanks Niklas,
    I was using "prepered for pickmaster option"
    BR
    Oscar Ferrrato
