Flexpendant startup problem
rixmaia
in ScreenMaker
I use the Robotstudio 5.11.02 and the Screenmaker 5.11 but not work.
When the flexpendant start, show that message:
Cya
Ricardo
rixmaia2009-02-20 20:29:10
No more one word!
Hello,Carlos is right, this type of error typically occurs when the FlexPendant Interface option is not installed in the Robot Controller or Virtual Controller. This option is required.Kind Regards,Steve0
HiJust to elaborate the above answer's from Carlos and Stevetry the following steps1. Create a System from System Builder (Online Tab) of Robot Studio 5.112. while creating please ensure that you select the PC-Interface option(616-1) and FlexPendant Interface option (617-1) form Modify options menu while creating system from Online. (needs appropriate controller Key for these options)3.Then Go to Robot Studio Home tab and creat new station ...use " Existing system" template then select the system you have created from system pool (Now your VC is ready)4. Now you try to create the Screen Maker application ( or open the existing Screen Maker application) and see if your application works.sunil sabut2009-02-25 16:46:06Sunil Sabut
India Corporate Research
ABB - India0 -
Ops,
I thought it worked as the applications created by the RAB...
Thanks for all!
Ricardo
No more one word!0 -
In fact id does
The FlexPendant Interface option (617-1) allows a customized application (either RAB or SM) to run inside the system.The PC-Interface option(616-1) allows the ScreenMaker designer to access to the controller in order to connect data.SaludosCarlosCarlos Martinez
so if i understand it right, the PC-interface is only necessary in virtual environment, not on the real robot itself for running the screens0
Yup ...The PC-interface provides access to the controller data from an network PC connected. This option is needed by ScreenMaker only while you are designing the screens.At design time, if you want to access the controller data (either virtual or real controller)from the ScreenMaker designer, you need this optionFor running screens, you do not need this option.Carlos Martinez
ABB0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
