editing project made in SM by hand
jawojtek
in ScreenMaker
Hello All,
I have a following question:
Is it possible to edit project made in SM by hand? Say that I'd like to add some functionalities that cannot be done in SM. I belive that some informations are kept in .view files and that files are not editable. Is using external library the only solution?
Obviously I could do all code in RAB but I like the screen management mechanism implemented in SM by default. I'd like to avoid all the disposing stuff, too.
Thanks a lot for all replies.
jawojtek2009-03-04 14:02:53
Wojciech Wlodarski
PLABB
PLABB
Hi, <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The .view files are binary files. There are different ways to extend the SM functionality:
- After making all your screens inside SM,, generate the c# files and create a VS.NET project. This is doable and it is planned to be automated in a future release
- Create a user control with the functionality that you want to add, and add it to the ToolBox. In this version, this methodology is not fully documented and tested.
I could support you in both scenarios. Just remember that SM is still on a CTP status.
Carlos Martinez
carlos.martinez@us.abb.com
Carlos Martinez
ABB0
