backup while robot is in automatic mode
hello all,
does somebody knows if it is possible to create "automatically" backups from the robot. I would like to create everytime the robot - system clock passes midnight automatically a backup from the robot.
is this possilbe? which instruction does I have to use, does I need extra options to perform this?
thanks in advance,
bart
best regards,
bart
bart
You could do this with RAB, you would need the FlexPendant Interface option and/or the PC Interface option, depending on whether or not you wanted to have an external PC trigger and retrieve the backups.Russell Drown0
hey RussD,first of all thanx for your quick response..... what is RAB and where can I find information about it?thx,bartbest regards,
bart0 -
There is a topic elsewhere iin this forum under Developer Tools for Robot Application BUilder, also on the ABB website there is product info.Russell Drown0
hey russD,thanks for your information. currently I'm reading about RAB and the SDK but I have just one more question. Can I do something as I described previously also with S4C+ controlers or is there no way?regards,bartbest regards,
bart0 -
I don't know of a way to do it from the teach pendant on the S4C+, but with the WebWare SDK product + FactoryWare Interface option you could create a PC application that forces backups. Also, there is a product called WebWare Server that does all of this for you out of the box, but may be too expensive depending on the # of robots you have. WebWare has a forum topic aslso and is described on the ABB website as well.Russell Drown0
Greetings,If your robot has multitasking you could write a background task to save the necessary modules to a storage device automatically. That seems the easiest and most cost effective solution.Lee Justice0
