Transform i VBA RS 3.0
When i use the transfom function i transfer from world coordinate.
when i recive my transform.x and transform.y
y= xpos of part and x = yPos
How do transfer from USC or localpos.
Best regards Klaus
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
I would put a little more effort into describing my problem if I where you.
I had to read your post 3 times before I understood what you where asking for.
'How to create objects in relative orientations
Sub CreateTargetInLocalX()
Dim tgt1 As Target
Dim tgt2 As Target
Dim tfmT As New TransformSet tgt1 = ActiveStation.Targets.Add
tgt1.Transform.z = 1
tgt1.Transform.Ry = UnitToAPI(rsQuantityAngle, 45)
ActiveStation.UCS = tgt1
Set tgt2 = ActiveStation.Targets.Add
tfmT.z = ActiveStation.UCS.OffsetTransform.z + 0.5
tgt2.OffsetTransform = tfmT
ActiveStation.UCS = ActiveStation
End Sub
John
Developer Center0
- 858 RAPID Programming
