hot edit
carmila
hi,
is hot edit only can edit the position in main procedure only? I have a main module that contain many procedures. ANd there are some robtarget that only called in a procedure outside the main procedure. when i want to edit this robtarget using hot edit, i can't. Hot edit only show the target that contain in main procedure.
is any way i should take to edit the target outside main procedure?
Thank you
BR,
indah carmila
Hi.The manual says that the targets has to be global. You can't edit them if they are declared local in a routine.BR/cba0
So.. It's mean .. if i change the declaration LOCAL unto GLOBAL, I can edit them via hot edit?
I will try it.. (my computer is under repair, so I can't try now
)Thank you CBA!BR,indah carmila0
- 367 IRC5
- 858 RAPID Programming
