teach target defaulting to joint target
On one of my stations the 'Teach Target' button has changed it's default to creating joint targets. How do i restor the default so that it creates a normal target?
thanks,
Hugh
Hi Hugh,
You have to select the target type in the status bar at the bottom of the screen.
I didn't notice it either!
See:
http://forums.robotstudio.com/forum_posts.asp?TID=2596&KW=&PID=7869#7869
Kevin
Thanks Kevin, good to know I'm not alone.Hugh0
- 348 IRC5
- 846 RAPID Programming
- 21 AppStudio
