Hide application in ABB menu
Kevin
in ScreenMaker
I do not wish my ScreenMaker application to appear in the FlexPendant ABB menu.
Instead the screen must be displayed by my Rapid program using 'UIShow'.
I have tried using a blank icon and a blank caption in Project Properties, but if I click on the white space in the ABB menu the screen is displayed.
Is there a way to exclude the application from the ABB menu using ScreenMaker?
Thanks,
Kevin
Thanks,
Kevin
Hi ...
Try to remove the file: TpsApp*.gtpu.dll and try to UIShow RAPID instruction.Never try this my self, but it should work ..BRCarlos Martinez
Hi Carlos,
I deleted my TpsApp*.gtpu.dll file from the VC then warm-started and launched the VFP.
The application was not in the ABB menu, as expected, but UIShow caused an execution error because TpsApp*.gtpu.dll was not found.
Could I leave TpsApp*.gtpu.dll in place, but manually edit it to prevent it showing in the menu?
Any other ideas?
Thanks,
Kevin
You are right .. you are trying to launch the screen from that dll .. try this ..
(1) This is your RAPID code:UIShow "ViewTest_Screens.gtpu.dll", "ABB.Robotics.SDK.Views.MainScreen";
(2) Rename the file "TpsViewTest_Screens.gtpu.dll" to "ViewTest_Screens.gtpu.dll"This should work ...Carlos Martinez
Hi Carlos,
That works OK.
Thanks a lot.
Kevin
