Conveyor Tracking option in RS v5.11.02
I was desperately waiting for this option in RS called "conveyor tracking"
With this we can track objects passing through a defined path and the robot in turn can pick up just like in 'real time' applications
I'm able to create a 'conveyor tracking path'. But I'm confused to how to use it for the purpose
I'll be really greatfull if someone can send/upload a video describing the whole process
Regards,
Saurabh Vashist
Saurabh Vashist
Hi Saurabh,I have a PowerPoint presentation that covers the basics.It was made for internal use, so I'm posting it as is.Maybe it can help you out:By the way, have you tried consulting the Operating Manual?Conveyor tracking is a bit tricky to get started with so I would like to know if you found the manual helpful or not...There is also a demo station in the installation.0
Hello,Please see the attached images which shows that when I include a conveyor as a library option, it does not show in the drop-down menu for 'conveyor tracking' option.But when I disconnect the object from the library, 'conveyor tracking' option shows the object in the drop down menu.Is this due to some procedure OR is that a bug ?Regards,
Saurabh Vashist0 -
Hi,This is not a bug, a part which is imorted as a library is write protected until itA's disconnected from library.So to be able to use it in "Create Mechanim" and compile it to a mechanism, it must be disconnected. This is the same for all types of mechanisms.Best regards,
Hello Anders,
Thanks for your reply..
I already using same procedure. Just got a thought that may be there is another way out to this
Regards,
Saurabh Vashist0 -
Hello,Please see the below image which is self-explainatory for my problem.Can anyone suggest how to get these "cfg" files for custom made mechanism and conveyors with conveyor tracking option ???Regards,
Saurabh Vashist0 -
Hello,Is there no option or resolution for my problem
Regards,
Saurabh Vashist0 -
Try the attached cnv.cfg file for your conveyor or build your system using the attached PROC.cfg file.
webwiz/1178/PROC.zip
webwiz/1178/cnv.zip
To use conveyor tracking, you need to select the option "606-1 Conveyor Tracking".
In "Create System from Layout" you should only select your robot, not the conveyor. When the system starts up, RS will ask for a mechanism, now should a mechanism of the type Conveyor be selected. No special cfg files are needed.
ABB Robotics0
