hi.
I need a tutorial on how to create a multimove station in RS 5.10 with two robots doing different stuff. From A to Z . Who know were can I find such tutorial. I tried to make an station myself but I need some help. Please!
Cristian Gidinceanu
welder. engineer.
welder. engineer.
nobody knows or have the time to show me???
Cristian Gidinceanu
welder. engineer.0 -
Hi,The Create Station from layout tutorial at this link http://www.abb.com/product/ap/seitp327/04a7e77286113ac1c1257427005a5498.aspxshows how to make a 2 robot with arc welding postioner station.RegardsGraeme0
If you know the 'Create System From Layout' option then you are 30% done with the step towards creating a multimove system. Just import the volume of robots you wana run in multimove (offcourse not exceeding 4) and just create system from layout and the system will create a system with multimove in-built.
For example see below:
--*--*--*--*--*--*--*--*--*--*--*--*--*--T_ROB1 for robot1::
PROC main()
ID1:Home;MM1;GOTO ID1;ENDPROCPROC Home()MoveAbsJ jpos10, v1000, z1, tool0;ENDPROCPROC MM1()MoveJ p10, v1000, z1, tool0;WaitSyncTask sync1, task1;SyncMoveOn sync2, task2;MoveJ p20ID:=10, v1000, z1, tool0;MoveJ p30ID:=20, v1000, z1, tool0;MoveJ p40ID:=30, v1000, z1, tool0;MoveJ p50ID:=40, v1000, z1, tool0;SyncMoveOff sync3;ENDPROC--*--*--*--*--*--*--*--*--*--*--*--*--*--T_ROB2 for robot2::
--*--*--*--*--*--*--*--*--*--*--*--*--*--PROC main()ID2:
Home;MM2;GOTO ID2;ENDPROCPROC Home()MoveAbsJ jpos10, v1000, z1, tool0;ENDPROCPROC MM2()MoveJ p10, v1000, z1, tool0;WaitSyncTask sync1, task1;SyncMoveOn sync2, task2;MoveJ p20ID:=10, v1000, z1, tool0;MoveJ p30ID:=20, v1000, z1, tool0;MoveJ p40ID:=30, v1000, z1, tool0;MoveJ p50ID:=40, v1000, z1, tool0;SyncMoveOff sync3;ENDPROC--*--*--*--*--*--*--*--*--*--*--*--*--*--Regards,
Saurabh Vashist0 -
thank you
Cristian Gidinceanu
that's was verry helpfull. I did that and works fine.
Cristian Gidinceanu
that's was very helpfull. I did that and works fine.
Cristian Gidinceanu
welder. engineer.0
