system variable manual status
Are there any system variable that tells whether the robot is in manual mode or automatic mode?
I want to remember whether the robot has been in manual mode, to use when performing reset.
  • Klaus
    Klaus ✭✭
    Hi.
    There system output "AutoOn" that is high when the robot is in automode. If you have miultitasking you can make a semistatic task that set a boolean when auto is on. otherwise you need a hardware relay to connect to an output crossed to system output AutoOn
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
