ScreenMaker and RS5.12
Hi there,
i had to setup my PC completely new due to some deleted things....
Now i have instlled RAB 5.12, RS 5.12 and RW 5.12.
Finally i installed the recompiled Screenmaker 5.12. Whn i then start RS 5.12 with a controller active, and try o start ScreenMaker, the attached error message comes up.
Who can give me a help on this?????
This is an urgent item, as i wanted to show the Screenmaker next week in an internal produt presentation to make the guys promoters of Screenmaker....
Regards
Thomas
Hi Thomas,This erros comes when there is a mismatch in the version. We will try to fix these errors.In the meantime, where did you get ScreenMaker 5.12?ThanksCarlos Martinez
Hi Thomaswhich build of Screen Maker 5.12 are you using ? if it is the latest Screen Maker 5.12 executable (ScreenMaker.5.12.3076.0138), then please try to remove your RAB 5.12 from your laptop /PC and then load the above Screen maker build. you may get a solution ...Try a released build of RS5.12 ( Avoid any RS 5.12 Revision build)Let's know if you could get a solution.Regardssunil sabut2009-05-06 05:03:00Sunil Sabut
India Corporate Research
ABB - India0 -
Hi,during the test of the RW 5.12 release candidate here in germany we got contact with Steve via Jonas Stigeberg and he gave us the version 0135.This i have used even with an installed RAB 5.12 RC without problems, therefore i reused it with the final RS version and the final RAB version installed as well, resulting in the posted error....RegardsThomasPS.: By the way, we (you or who else at ABB) should post the latest verson always at the download page in the developer section....0
There is a ScreenMaker 5.12 CTP "recompile" now available for download on the Downloads site.Steve0
