Flexpendant Viewer......
Jaaahhh
Does anybody know how I can use the feature 'Flexpendant Viewer' with a online Robotcontroller?
I get an error all the time in the 'Output window'!
Jaahhhh
Are you connected as a UAS user with less than full access? There is a known issue with this scenario. What version of RS and RW are you using?
Russell Drown0 -
RussD,I am using the same software-hardware as Jaaahhh:RobotStudio 5.12RobWare 5.12.0Windows XP SP2We are logged in as Programmer with all rights.The error message is:RobotStudio .NET exeption: Flexpendant capture failed.Base exception: COMExceptionExeption from HRESULT: 0xC0040401 at RobotStudioOnline.AppWindows.FlexpendantViewer.CaptureCompleted(AsyncResult result)Regards,MD0
Look at your default user specifically, it must have full access or else the FPViewer won't work. It doesn't matter what user you are logged in as, I think FPViewer uses default user to access, so if it doesn't have full access it won't work. This is scheduled to be fixed in 5.12.01.
Russell Drown0 -
Russ,You are right.
Just another ABB bug? If you give the default user full access then the Flexpendant Viewer is working. For now this can temporarely be a workaround. When is 5.12.1 expected?Mario and Luigi will be happy.Ciao from Italy0 -
It should be available somewhere around week 24-25, i.e. mid June.Russell Drown0
- 87 OmniCore
