Image Path
What is the path that I should use if I have a bmp that I want to load in a picture box?
pbScreenGraphic.Image = new Bitmap("/HOME/Idle.bmp");
thanks!
Shane
You can use the TpsResourceManager to load the image. This class has a method called GetImage, which will load the file from you,TpsResourceManager tpRM = TpsResourceManager();pbScreenGraphic.Image = tpRM.GetImage("Idle.bmp"); <- if possible, change this to JPGThe image file Idle.bmp should be in the system's home folder. After the FlexPendant restarts, all images located in this folder will be copied into the FlexPendant, from where the TpsResourceManager loads them.Hope this helpsCarlos Martinez
Carlos,You are always there to help!Thanks0
Why can't I add the resource ABB.Robotics.TAF.Base? Am I missing something?
Shane0 -
what do you mean ... adding this assembly as a reference to your project?Carlos Martinez
Yes...... Man I am feeling a little stupid here, sorry. How do I add the reference. I thought it wasusing ABB.Robotics.TAF.Base;But it says I need to use version 5.11.11 or something like that.Shane0
Never mind!!! I remember now.
Sorry it has been a few months.Shane0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 739 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
