How to pass array arg to Function
Lin
I have on array A{1,1,5}
I would like to pass this array as a argument to my function.
FUNC ..... Name(num b{1,1,7})
ENDFUNC
Is this possible? If you know the answer, please help me.
Thank you.
ENDFUNC
Thank you.
Lingaa
hii not sure but tryFUNC ..... Name(num b{*,*,*})
ENDFUNC0 -
hi again
i found info in rapid overviewfor procedure
PROC arrmul( VAR num array{*}, num factor)
FOR index FROM 1 TO dim( array, 1 ) DO
array{index} := array{index} * factor;
ENDFOR
ENDPROC0
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 740 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
