graph control RAB 5.12
kioog
i am trying out the graph control.
i use
Double[] PX={1,2,3};
Double[] PY={3,2,1};
graph1.addpoint(PX,PY);
but when i execute the code, i do not see the graph, i tried different things like
graph1.refresh(), graph1.update() and so on, but i don't see nothing, only the axes, not the data.
Can we draw different lines in the graph with different colors?
can i have some info or a working example?
Any help?
when is there help available for all the new controls available from RAB 5.11?
P.S. maybe this is offtopic, but on one real controller i cannot use hyperterminal to debug memory management, i connect it to the console port, i can see the messages when booting and everything, but when i press "enter", i don't get the "->" arrow so i cannot type any commands. any idea? hardware failure?
on another controller it works fine, so it is not my cable or computer.
Is there a possibility to read the available memory of the FP and write it to a RAB screen?
Kind Regards
Peter
Peter12009-05-15 09:28:43 0
Hi Peter ...I have not tried this code in the RAB 5.12. Could you verify it works?Thanks
Carlos Martinez
Hi carlos,the code works, i use RAB 5.12 on robotware 5.11.02.I forgot the define the plotstyle.I have a question about the graph controlIf i use:graph1.XAxis.minvalue=10;graph1.XAxis.maxvalue=0;the plot is still plotted in X from 0 to 10.so is there another way to plot Xdata from 10 to 0 for exampleI want to do this, because i want to plot measuredata in function of a robotposition in search, but sometimes the movement is in +X and sometimes the movement is in -X, but i want to plot the measures from start to finish.For the moment i make the Xmeasures negative in case of -X searching so my plot plots well,but now i see negative X numbers on the plot, but if it is not possible another way i can live with that.Kind regardsPeterPeter12009-05-15 13:16:430
Hi Peter,Can you send me the RAPID modules or data you are planning to graph?I can't promise anything, but we can see if there is a workaround ...BRCarlos Martinez
Hi carlos,i am reading a log file created in rapid by the robot on a background task that is recording the current robot position and an analogue input while moving the robot.the data in the logfile is for example:1/50/3002/55/2503/60/2104/65/400where the first data is datacounter, the second the robot X position, the third an analogue input from height sensorbut when i am searching in the other direction my logfile is1/65/3002/60/2503/55/2104/50/400for the graph control i now read this logfile line by line, use the second data as Xvalues and the third data as Y-values.i did it before with drawline,drawellipse, drawstring and calculate the coord of drawing on the screen including scaling and labels on the axis, but is was alot of work.i created a 4th data with the position starting from 0, used this data as Xaxis to draw the lines on the screen and use the second data to show the labels ( for example Xmin=65 and Xmax=50.with the graph control it would be a lot easier and a little fancier.another question:when i used drawline, drawellipse and so on, when i leave my RAB window (for example to view "production window") and then go back to RAB window, my drawings are gone, i use the form.onpaint method to redraw them, is that normal behaviour and the right way to do it?0
Hi Peter,How is all things going on?Carlos Martinez
ABB0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
