Importing parts in 5.12
                    SJT1985
                    Wow - lots of forum postings lately!
                I am having trouble importing parts into RS 5.12.  In 5.11, I would use ProE to save as a STEP file, and that worked well.  It seems that 5.12 did away with STEP files, and I am left with .sat, .stl, and .wrl.  None of these work for me.  .stl and .wrl give an error saying it cannot import the part, and .sat files successfully import, but the part is invisible.  Please advise.
            Hi try switch to another render OpenGL or Direct3D depending on which one you are using know.Per Svensson
 Consat Engineering0
            Hi,The CAD import should be the same in 5.12 as in 5.11. Are you sure your license for the STEP converter is valid?Best regards,
 ABB Robotics0
            Per, I tried switching to OpenGL, but it did not change anything.Anders, please explain - is the step converter a part of RS, or external? I am confident that the ProE license is valid.When I ordered RS, I did not buy the Cad converter, I only bought RS and ArcWeld PowerPac. Is this the problem?Also, when I import the .sat file, I get an error that reads: "Geometry (ACIS) warning 60013, Tolerances of restored file do not match current tolerances" Perhaps this is why the part is not visible.0
            HiTo be able to use the step converter in RS you need a license for that.To test that your acis file is ok you can download Hoops 3D part viewer from spatial (it's free)Per Svensson
 Consat Engineering0
            By the wayDid you restart RS after you have changed to OpenGL?Per Svensson
 Consat Engineering0
            After trying to open the file in Hoops 3D, I had the same problem. The part was not visible, which leads me to believe this is a ProE problem, not a RS problem.Also, the license to use the step converter, is that part of the cad converter pack?0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
