where can I get the manual?
in ScreenMaker
Is there a manual available? I have only just got this software and started playing but keep getting and error each time I try to build/deploy - "ScreenMaker -> Build Error -> Screen - Line 0 : Predefined type 'System.Object' is not defined or imported [6] 19/05/2009 16:17:07 ScreenMaker
Hi,Which versions are you running?RobotStudio -RAB -ScreenMaker -Carlos Martinez
Hi. RW 5.12 and RS 5.12 and SM 5.12.
So form this there is one at leats available for Sm 5.11??
thanks
dazza
So from this there is one at least available for Sm 5.11??
thanks
dazza
(correct spellings this time)...
Hello,You should find the Application Manual for ScreenMaker under:"c :Program FilesABB Industrial ITRobotics ITScreenMaker 5.12"However, the error you are getting sounds a bit more serious than what would be covered by the manual. Can you send more information on the state of your PC (what was installed before, other programs, etc)Kind Regards,Steve0
Hi Steve, Thanks for your input. I found the manual.
I have uninstalled all my ABB products. Done a windows update (no
updates necessary). Then I reloaded RS 5.12 and screenmaker 5.12 CTP.
Launched robot studio and opened my saved station. synched it to the VC
and then launched screenmaker. But upon loading I get this error "unable to get the .NET Compact Framework folder". I OK this and then a few more detailed errors are dispalyed and then the application starts. I can do stuff like buttons and events etc but when I press build it shows the error mentioned in previous posts.
Any ideas?
HiTry to load .NETCF from "http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=e3821449-3c6b-42f1-9fd9-0041345b3385". Try with .NETCF2.0.RegardsSunilSunil Sabut
India Corporate Research
ABB - India0 -
Thanks you Sunil. Will try this after few days holiday.
dazza
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
