Target with Noname
Petri
I use Target with NoName (mark with *) when I program real robot, is it possible to use that in RS?
When I sync to station it works wine, but other direction not, even though I rename targets similar that they look in object browser.
My RS is 3.0
T.Petri
RS 3.0 supports inline targets (*). Although all targets need to have a name as graphical object.
When you sync a path from a real robot with inline targets, you get names like il1 and so on.
If you create targets in Robotstudio, you need to select them in the object browser and then change the property "Inline" in the property browser to "TRUE"
You can select them all together and change the property...
regards
Christian
regards
Christian0 -
Thanks , this is working fine
Regards
Petri
- 367 IRC5
- 858 RAPID Programming
