VAR, PERS,and CONST
Dear all,
I've been informed that PERS data can be stored unless the controller is shut down, but, in my case, the data using PERS is gone after I turn off the controller. Can anyone know what is the conclusions to make data is kept store unless the controller is shutdown, even if I load a new program?
Thank you
BR,
indah carmila
Try to create your variable, pers, const in different module.
and ensure that before starting new program. r u saving the current program properly.
If any errors, please try to save each module separately.
Lingaa0 -
Dear Lin,
OK, I will try it. So, when I restore my system, I only load the module that contain my datas. Is it right?
BR,
indah carmila0 -
Hi Carmila.Have you init your PERS with a Value?PERS Num Name:=0;BR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Dear Klaus,I only write:PERS num name;only that. Is any differences with and without a value ( PERS num name : 0)?Thank youBR,indah carmila0
Dear Klaus,I only write:PERS num name;only that. Is there any differences with / without a value? ( PERS num name :=0)Thank youBR,indah carmila0
Hi Carmila,
Persistent variables must have an initial value. When u change ur variable value, initialisation value of that persistent updated. So when u load module again controller creates persistent with last initialisation value and that keeps it unchanged.
Erdem Karaçeper0 -
Hi Camaile.That's why it don't work. PERS without init value will do the same as a VAR and not remember the value. Even PP to main will delete the valueBR KlausBest Regards
Klaus Soenderhegn
Dear Klaus and Charon,
Thank you for your information.A?
I will change it.A?
BR,
indah carmila0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
