formula in mechanism dependencies
Can anyone tell me the correct syntax rules for a formula in the mechanism dependencies dialog?
Hi Dean,
You can write a mathematical expression with the joint names as variables. Available functions are sin, cos, tan, acos, asin, atan, atan2, sqrt, pow. For example:
atan2(140.0 * sin(J1),619.53 - 140.0 * cos(J1))
regards,
Johannes
Johannes Weiman
Thanks! It seems it likes the spaces between operators.0
- 858 RAPID Programming
