Recompiling problems
Hello
I have a problem recompiling a project.
This is the reproduction of the problem
* I have a correctly running project on virtual Flex pendant
*I save and close VS. Net
*I reopen the same project
*I recompile the project (no modification on it)
*the project is not more visible in th e flexpendnt
*(Workaround I found: Create a new project and copy manually the text file from the old one.this new project will work until I 'll close it again...)
*I suppose I miss some setting in VS.Net. Any suggestion?
Oscar Ferrrato
I'm not sure I understand your problem.
You state that you close and re-open your VS.Net project, and that after re-opening and recompiling the project you cannot open/see your application on the VFP.Are you building the exectuable .dll and running the compliance checker in one step? How are you deploying the executable and proxy .dll to the VFP?
Your previous executable file that you deployed to the VFP should still be in the file system until you explicitly deploy a newer version of the executable or delete the old file.
You should try to provide additional information about which version of FPSDK, VC, RW, etc. that you are using.
Russell Drown0 -
Hi Russ
in fact the problem was that if I reopened a project, rebuilt the dll and deployed it again , it was not working anymore.
I solved it updating the robotware on the VIRC5 from 5.5.80 to 5.05.129
Thank you any way for yor fast answer.
Oscar
BR
Oscar Ferrrato0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
