Heat Sink error [ArcWelding PowerPac]
Hi all,
I am new to this application area.
I have ARISTOROB 500 power source model with my S4 Controller.
I am getting the following error number.
Error No: 117206
Welding equipment error
Temperature in power source heatsink too
high. Inverter is shut down until
temperature switch is closed again.
Check:
Ensure that there is no obstacle that
reduces the cooling airflow that passes
through the heatsink of the powersource.
Wait until temperature switch is closed.
I have to replace the heat sink for this error. or airflow checking is enough.
Please help me to solve this error.
Thank you in advance.
Error No: 117206
Check:
Lingaa
I suggest you contact your local service guy.
you must controled the equepment of lal 500 welding machine.your problem in lal 500.
