Collision error handling
I have this collision error handling:
The case is this:
1)there is a collision
2)during the retractive movement of the collision there is an other collision
In this case Yumi is not able to restart with the play button.
The play has no effect and there's no other error message.
I have set the program pointer to main and start from main.
Is there any way to fix this and restart without PP in Main ?
Robotware version is 6.04.
Thank you
PROC main()
ERROR
IF errno =ERR_COLL_STOP THEN
ERR_COLL_HANDL;
RETRY;
ELSE
TPWrite "errore generico";
GENERIC_ERROR:=TRUE;
stop;
ENDIF
PROC ERR_COLL_HANDL()
IF DOutput(vo_L_inzone)=1 THEN
RETURN;
ENDIF
stop;
ERROR
stop;
The case is this:
Thank you
