Task Executing system output change
Janno
Hello
in my company we use robots with multitasking by default.
to check in the maintask if all semistatic tasks are running we used (from RW 5.15 till now) the task executing system outputs
i just found out while starting a new project that the RW 6.05 (SP1) doesn't allow semi static tasks on the task executing system output anymore.
is there a specific reason for this change? and can we expect this system output to be reverted to old functionality?
Edit:
I removed the task executing system outputs. manually put them back in through robotstudio.
now it works, saved the EIO.cfg and this file is identical to the 1 i loaded earlyer
Edit:
