Pickmaster RIS Proxy setup to Compact Logix AB PLC
curtis24
Hey all,
I recently setup a single pick and place flexpicker robot cell. I want to get the RIS setup working to start and stop the pickmaster project from the PLC. After I configure the RIS setup on the Pickmaster PC what do I need to do or add on the PLC end to read the data in and send the data out. Do I need to install something further other than RIS on the pickmaster PC? any help to complete this would be appreciated.
Hi Curtis, Did you get any info...i'm stock with the same problem?
- 38 AppStudio
