Measurment Tool Improvement
Options
Like this:
Anyway, I guess you mean the measurement end points are "attached" and updated when an object is moved? Sounds like a very good idea.
Regards,
Johannes
Johannes Weiman
Software Engineer
Thank you Johannes, but this button does not work.
I can choose a pic, but it does not insert it into the comment!? This drop-down menu keeps visible after opening a pic, and I'm missing something like an "OK" button.
About the subjekt:
No I'm not talking about moving an object (though this is a good idea also). I'm talking about a better visualisation of the three x,y,z vectors of a measurment result.
Something like this:
http://ww3.cad.de/foren/ubb/uploads/MarcoJ/MaxAbstand.JPG
I found that the image insert does not work in windows internet explorer - OK in Chrome.
OK,
I'm not allowed to install other browsers than IE.
So it would be nice if this could be fixed.
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
