Export all Logs
Hello everbody, I got a small Problem. I tried to export all log in Categorys from one real Robot.
I treid to do this in C#, but it will not works. I would be need only the messages, Date, and stuff from the Log.
Later i will put this Stuff in a Database.
Any one do something like this?
  • You need to create an instance of EvetLog class and sign with the controller and EventLog properties of that controller.
    After you need to create a new variable var and assign that newly created instants with GetCategories properties to that variable.
    And use foreach to go through that variable and so on.
    Example:
    class ControllerLocater
            private string outputLine = null;
            public string OutputLine { get { return outputLine; } set { outputLine = value; } }
            private string errorBody = null;
            public string ErrorBody  { get { return errorBody; } set { errorBody = value; } }
            private string bodyText = null;
            public string BodyText  { get { return BodyText; } }
            public void controllerOutput()
                NetworkScanner ntScann = new NetworkScanner();
                ntScann.Scan();
                ControllerInfoCollection controllers = ntScann.Controllers;
                Controller ctrl = ControllerFactory.CreateFrom(controllers[0]);
                EventLog log = ctrl.EventLog;
                var categories = log.GetCategories();
                foreach (var c in categories)
                    for (int p = 0; p < c.Messages.Count; p++)
                        bodyText = c.Messages[p].Body;
                        // some text editing. Not complited – just as an exampl
                        TextEditor();
                        Console.WriteLine($"/nType of Log - {c.Type.ToString()}");
                        Console.WriteLine($"/n{errorBody}");
                    c.Dispose();
            } // end of controllerOutput method
            public string TextEditor()
                outputLine = Regex.Replace(bodyText, "<.*?>", System.String.Empty);
                //ar = Regex.Split(outputLine, pt);
                //Console.ReadKey();
                outputLine = Regex.Replace(outputLine, @\.(?! |$), ". ");
                outputLine = outputLine.Replace("1)", "\n\n\bActions \n1) ");
                outputLine = outputLine.Replace("2)", "\n2) ");
                outputLine = outputLine.Replace("3)", "\n3) ");
                errorBody = outputLine;
                return errorBody;
            } // end of TextEditor method
        } // end of ControllerLocater class
