Robot programming
Anand95
I I am working on Irc5. When starting the robot after power failure it does not start on auto mode. Need to do remaining welding on manual mode.why it is not starting in auto mode. Plz help?
What messages are showing in the event log? In particular, "restart not possible".Lee Justice0
I've had that problem before check your safty circuit
The safty block read correct but the outputs to the robot was wrong
- 400 UpFeed
- 20 Tutorials
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 350 IRC5
- 74 OmniCore
- 848 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
