Operation is illegal in current execution state
LeonL
LeonL
edited August 2019 in Collaborative Robots
I am observing sporadic behavior of this "Operation is illegal in current execution state" error when running a C# application written using the PC SDK. I make sure to check that the 'TaskExecutionStatus' is stopped so that the program pointer is not moved while the program is executing, however the error still occurs. How can I tell what is going to cause this error since it seems to be happening randomly?
This is the error output, followed by the C# code snippet of how I am executing routines:
ABB.Robotics.GenericControllerException occurred
  ExtendedErrorInformation=""
  HResult=-1073442809
  Message=C0049007 : Operation is illegal in current execution state.
ERROR: rdh_rapid.cpp[7215]: org_code: -4503 new_code: 0xc0049007;
Url:/RAPID/T_ROB_R  Cmd:SET  Prop:PP  Args:-ExLev N -RoutineURL /RAPID/T_ROB_R/MainModule/EmptyRoutine  Elapsed:0  CurrentCmds:0
History:
-00:00:00.5445383 [787536] SendCommand url:/RAPID cmd:Get prop:Childs arg:-mark 0 -noelts -1 -cc 0
-00:00:00.5415381 [787536] status:294912 data:-noelts,all,mark,cc     2,1,        21, ...
-00:00:00.5415381 [787537] SendCommand url:/RAPID/T_ROB_R cmd:SET prop:PP arg:-ExLev N -RoutineURL /RAPID/T_ROB_R/IoModule/GetVacuumPressure
-00:00:00.5180297 [787537] status:294912 data:
-00:00:00.5180297 [787538] SendCommand url:/RAPID cmd:SET prop:Start arg:-RegainMode Clear -ExecMode Continous -Cycle AsIs -Condition None
-00:00:00.0430038 [787538] status:294912 data:
-00:00:00.0419938 [787539] SendCommand url:/RAPID cmd:Get prop:Childs arg:-mark 0 -noelts -1 -cc 0
-00:00:00.0370044 [787539] status:294912 data:-noelts,all,mark,cc     2,1,        21, ...
-00:00:00.0370044 [787540] SendCommand url:/RAPID/T_ROB_R cmd:Get prop:ExecutionState arg:
-00:00:00.0350017 [787540] status:294912 data:-ExecutionState Started
-00:00:00.0340022 [787541] SendCommand url:/RAPID cmd:Get prop:Childs arg:-mark 0 -noelts -1 -cc 0
-00:00:00.0280013 [787541] status:294912 data:-noelts,all,mark,cc     2,1,        21, ...
-00:00:00.0280013 [787542] SendCommand url:/RAPID/T_ROB_R cmd:Get prop:ExecutionState arg:
-00:00:00.0250037 [787542] status:294912 data:-ExecutionState Started
-00:00:00.0140031 [787543] SendCommand url:/RAPID cmd:Get prop:Childs arg:-mark 0 -noelts -1 -cc 0
-00:00:00.0130003 [787543] status:294912 data:-noelts,all,mark,cc     2,1,        21, ...
-00:00:00.0130003 [787544] SendCommand url:/RAPID/T_ROB_R cmd:Get prop:ExecutionState arg:
-00:00:00.0120031 [787544] status:294912 data:-ExecutionState Stopped
-00:00:00.0009889 [787545] SendCommand url:/RAPID/T_ROB_R cmd:SET prop:PP arg:-ExLev N -RoutineURL /RAPID/T_ROB_R/MainModule/EmptyRoutine
00:00:00 [787545] status:-1073442809 data:ERROR: rdh_rapid.cpp[7215]: org_code: -4...
  Source=ABB.Robotics.Controllers.PC
  StackTrace:
       at Adapters.Task.SetPCPToRoutineByUrl(String routineUrl)
       at ABB.Robotics.Controllers.RapidDomain.Task.SetProgramPointer(String module, String routine)
       at Msei.Fsd.MpxRobot.AbbRobotArm.RunRoutine(String moduleName, String routineName, Boolean checkComplete) in C:\Users\floorp\Documents\mpxmic\Msei.Fsd.MpxRobot\AbbRobotArm.cs:line 868
  InnerException:
       HResult=-1073442809
History:
       RawMessage=ERROR: rdh_rapid.cpp[7215]: org_code: -4503 new_code: 0xc0049007;
       InnerException:
C# Snippet
private void RunRoutine(string moduleName, string routineName, bool checkComplete = true)<br>        {<br>            Task task = Controller.Rapid.GetTask(Task);<br>            task.SetProgramPointer(moduleName, routineName);<br>            Controller.Rapid.Start(true);<br><br>            TaskExecutionStatus status = Controller.Rapid.GetTask(Task).ExecutionStatus;<br>            while (status != TaskExecutionStatus.Stopped && status != TaskExecutionStatus.Ready)<br>            {<br>                status = Controller.Rapid.GetTask(Task).ExecutionStatus;<br>                Thread.Sleep(10);<br>            }<br><br>            // Set the program pointer to an empty routine so that if this task is run again, nothing will happen.<br>            task.SetProgramPointer(ModuleDefinitions.MainModuleName, "EmptyRoutine");<br>            if (checkComplete == false)<br>            {<br>                return;<br>            }<br><br>            bool isComplete = ReadBool(ModuleDefinitions.MainModuleName, ModuleDefinitions.CompleteFlagName);<br>            if (isComplete == false)<br>            {<br>                throw new RobotException(<br>                    $"Robot task did not complete successfully. module:{moduleName} routine:{routineName}");<br>            }
