Group various Digital signals into bytes
eKoh
Hello there!
I am simulating communication with PlcSim, but I need to send this information in bytes. For example let's say I have these digital output signals:
PLC_do_User_01
PLC_do_User_02
PLC_do_User_08
How can I group these into a byte?
And later on, connect that resulting byte within the Design of the Station Logic? As shown (incorrectly for now) in the following picture.
I would appreciate any help, thank you guys!
P.S. I am using RSConnectGIOToSnap7 Add-In.
PLC_do_User_01
PLC_do_User_02
PLC_do_User_08
Hello,You can make group in your controller, or you can use RSConnectDIOToSnap7.
For a virtual signal, click on I/O system, right click on signal and select "add".
For a real signal, the only difference is the mapping:
1 -
Thank you for your response!nomad5t5 said:For a virtual signal, click on I/O system, right click on signal and select "add".
I misexplained my issue. Let me expose the problem:
I have these 32 Digital Inputs that I want to group into 4 Groupal Inputs (let's say virtual signals).
The question is: How can I connect 8 signals into 1 Groupal signal?
My dummy solution was to write that code in RAPID in the background task I have on my controller, but that would be a really messy code. I am looking for a more elegant solution if possible.
Thank you guys for the response!0 -
Your snip is of real signals so in the device mapping (shown in Nomad's snip) you put in the start bit and the end bit of each group --> GI1 = 0-7, GI2 = 8-15, GI3 = 16-23, GI4 = 24-31.
The bit mapping on I/O devices normal start at 0, so your 32 bit would go from 0 to 31.
1 -
Man, thank you a lot! It did work!!!graemepaulin said:Your snip is of real signals so in the device mapping (shown in Nomad's snip) you put in the start bit and the end bit of each group --> GI1 = 0-7, GI2 = 8-15, GI3 = 16-23, GI4 = 24-31.
- 858 RAPID Programming
