Not able to add independent axis movement
I am using IRB2600 with external axis, MU200, am not able to add independent movement for any axis. The instruction INDAMove or IndCmove etc, is not even listed. can anyone help me pls
Do you have that option installed?Lee Justice0
What if you created custom jointtargets instead and used MoveAbsJ?0
Which option should i check for, Lee?
Independent Axes [610-1] is the option needed. Note that Independent Axis is not fully supported by Robot Studio simulation
In the newer versions (2020.1 and newer) of RobotStudio is Independent Axis fully supported.Best regards,
ABB Robotics0 -
How can i add the option, [610-1] to the existing controller?
You need to contact your local ABB office in order to purchase that option. They will make a new keystring for your system with that option included.Lee Justice0
- 38 AppStudio
