5.08 and dual core?
RussG
Does any one know if 5.08 works on a daul core processor yet?
Thanks, Russell
RUSSELLgee
Director
1/118 Connaught St Sandgate QLD Australia 4017
ph +61738694298
fax +61738693284
mob +61418116644
email russell@manmac.com.au
Director
ph +61738694298
fax +61738693284
mob +61418116644
I just finished setting it up on a Dell Precision M90 Intel:Dual Core. It works quite well. The only issue I have is that it seems slower calculating configurations at times. Other than that everything runs fine.0
My dual core still does not work with robot studio 5.08, it crashes constantly, I am guessing they are going to fix it in the next release I hope
you can get it working correctly by turning off the dual core feature in bios Dustin0 -
RS 5.08 has been successfully tested on dual core. However, RS is not yet optimized for dual core, so there is no performance advantage at this time. We will work on this for the 5.10 release.
Bert Thorvaldsson
Product Manager, RobotStudioBertil Thorvaldsson
Product Manager, Software Products
ABB Robotics0 -
Do you mean 5.09? or is there a new version of 5.08 because my rs 5.08 crashes when you try and load it having the dual core on or will not load the controller.
thanks,
dh_custompak2010-05-30 04:41:30Dustin0 -
I am using the 5.08 downloaded the day they released it. I am sure that until they address the utilization of dual/quad-core issue there will be problems with some systems. I do not believe 5.09 has been released yet.0
- 40 AppStudio
