RW 7.2 cannot compare group signal with num variable
Options
Hi ! There is change in RW7.2, it's now dnum. Use conversion.Have a look in 7.2 release notes - it's described there.Edit: Best way to solve it is to use GOutput function to get num value out from group signal.
1 -
Fritz said:Hi ! There is change in RW7.2, it's now dnum. Use conversion.Have a look in 7.2 release notes - it's described there.Edit: Best way to solve it is to use GOutput function to get num value out from group signal.
It works :-)
/David
Actually, as long as comparison is to dnum value no conversion (GOutputToDnum) is needed:
David
Swedish freelance ABB robot programmer0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
