Program does not execute continuously in the Main Module
I'm having a problem running the program continuously in PROC main ( ). When the controller is switched to Automatic Mode it executes the program in the PROC main ( ) but it stops after the program finishes and does not run continuously as it should.
Is the run mode (middle of RAPID tab) in continuous?0
You know, you are not required to be so specific about your location in your profile...Lee Justice0
graemepaulin said:Is the run mode (middle of RAPID tab) in continuous?
I'm not sure what you mean0 -
Thank you, this is a learning curve for me. I can't believe I missed such a simple mistakegraemepaulin said:
- 88 OmniCore
- 42 AppStudio
