I/O Configurator 6 not working with custom user
Hi.
We have removed the Default User permissions in a robotcell and created a custom user with the proper permissions.
When i'm logged in with a custom user and try to edit I/O signals with I/O Configurator 6 i get the error showed in the image.
However i'm able to change I/O signals with the default configuration in the "Controller" tab on robotstudio.
  • Did you login on the pendant or in RobotStudio?
    If only on the pendant use the Authenticate button on the controller tab to login.
  • Ofcourse I was logged in with robotstudio.
  • bump
  • Hello Tompan,
    If you find this to be a pressing issue, please contact your local ABB and ask for their assistance.
    If this is a bug it will get escalated internally.
    Thanks!
    Maxim Riabichev
    PC Software Support Engineer
