ABB_Calibraion_Manual
in IRC5
Hallo All,
this is my first project with ABB robot, got new robots and turned it ON, on Controller Start, it says 'Update Revolution Counter' then I looked in to documents and tried to update revolution counter.
As soon as I entered in to Calibration to update revolution counter, I saw robot is not calibrated, then I did Calibration by looking markings on Robot and updated.
But now my problem is, the calibration offset(Resolver Values on robot label and my calibrated values have little change(diff = +- 0,03)). Does this make any big diffrence?
Did you "fine Calibrate" each axis or merely update the rev counters?Lee Justice0
Hallo @lemster68 ,Many thanks for your reply. I fine calibrated each axis and then updates rev counter
You should not fine calibrate unless you have removed and replaced a motor. I suggest entering the values from the stickers and check the zero positions again.Lee Justice1
Hallo @lemster68
Many thanks for your reply,
Entering Zero positions on the stickers: Menu-->Calibration--> Manual--> Calibration Parameters --> Edit Motor Calibration Offset? Am I right or should I do Other way. Many thanks and Wait for your reply.
Hallo @lemster68 ,I changed the zero positions as if like it on Stickers, and turned it OFF and ON.Firstly, By Restart it says "Unsync Due to System Parameters"Secondly, Then I tried to Update my revolution counter, Then it showed up an event message 'Robot Memory Data Diffrence'I checked The cables they are connected it in right way.Could you please help me out mean while I look in to the documents. Thanks in Advance.0
Hallo @lemster68 ,Got Solved the problem, updated the zero values on the stickers and then in Calibration--> Robot Memory --> Update--> Update Robot Memory with Controller data, and then tried to update revolution counters then it worked out
now Im having same valeus on the Stickers. Thanks a lot
