How to read TCP speed from real robot: IRB 2400/16 RW:6.06.00
Kappa95
Hello community,
I need to read the TCP speed of the robot to check the motion law during the process. I have read different posts about the topic such as: https://forums.robotstudio.com/discussion/8285/how-can-i-read-robot-tcp-speed.
But it is still not clear to me which is the procedure and if i need a physical communication interface in how to read the TCP speed.
Thank you so much in advance
Best Answer
You can use a system output signal called 'TCP Speed'. Refer to the System Parameters manual for details.1
