How Can I read robot TCP speed?
Hi Everybody
I have a big question for you maybe answer can be easy for you :) I want to use robot tcp speed. For exaple I made a speed data as V125. And V125 TCP speed is 125. Then I want to see this value on my touch screen panel by profibus connection. I have a profibus unit on my units.
I tried to make virtual unit then
create analog output as deneme then
create system output as TCP speed on deneme
then tried to write this value to a group output but ı coundt
Please can you help me about this subject. I hope you can find a soulitoun for me :)
Thanks All
  • Hi
    You could try it with the following EIO.CFG
    Best regards
    Marcel
    EIO:CFG_1.0:5:0::
    EIO_BUS:
          -Name "Virtual1" -ConnectorID "SIM1"
          -Name "Profibus_FA1" -BusType "PBUS" -ConnectorID "FA1"\
          -ConnectorLabel "Profibus-DP Fieldbus Adapter"
    EIO_UNIT_TYPE:
          -Name "Virtual" -VendorName "ABB" -ProductName "Virtual unit"
          -Name "DP_SLAVE_FA" -BusType "PBUS" -VendorName "ABB Robotics"\
          -ProductName "Profibus-DP Fieldbus Adapter Slave" -InternalSlave \
          -PB_ProductId 6161 -PB_InputSize 50 -PB_OutputSize 50
    EIO_UNIT:
          -Name "ProfiBus" -UnitType "DP_SLAVE_FA" -Bus "Profibus_FA1"\
          -PB_Address 10
          -Name "UnitSim" -UnitType "Virtual" -Bus "Virtual1" -TrustLevel 0
    EIO_SIGNAL:
          -Name "aoSurfSpeedTCP" -SignalType "AO" -Unit "ProfiBus"\
          -SignalLabel "Surface Speed Robot in mm/min" -UnitMap "192-207"\
          -Access "All" -MaxLog 0.54612 -MaxPhys 0.54612 -MaxBitVal 32767
    EIO_ACCESS:
          -Name "ALL" -Rapid  -LocalManual  -LocalAuto  -RemoteManual  -RemoteAuto
    SYSSIG_OUT:
          -Status "TCPSpeed" -Signal "aoSurfSpeedTCP" -Arg1 "ROB_1"
  • Thanks Marcel ı will try that. Can I read current tcp speed?
    thanks again
  • With that configuration it will be sending the TCP speed out all the time because it's defined using a System Output which is always updating even if your robot program is stopped!
    thanks again
    Hello Ercan, Have you tried that ?
